General => Chatter => Topic started by: Rotary-Motion on February 16, 2013, 08:27:59 PM
Title: welding
Post by: Rotary-Motion on February 16, 2013, 08:27:59 PM
hi all
can i arc weld stainless and iron?
need to put lugs on like this pic
(http://img849.imageshack.us/img849/6921/image1361039687427475.jpg)
Title: Re: welding
Post by: K.H on February 16, 2013, 08:42:21 PM
You need His Royal Trumpetness, he will know
Title: Re: welding
Post by: Rotary-Motion on February 16, 2013, 08:52:24 PM
where is the roving wonderer ?
 :o
Title: Re: welding
Post by: Carrington on February 16, 2013, 09:57:28 PM
Hi shank
Yes you can arc stainless and iron  , you need to use dissimilar rods and be carefully with the different melt temps.
As said above Jim is the realy guy for fine details on this
Title: Re: welding
Post by: Rotary-Motion on February 16, 2013, 10:00:16 PM
thx
dissimilar ???
wats dat
Title: Re: welding
Post by: Carrington on February 16, 2013, 10:05:04 PM
It a rod for welding metals that arn't the same (dissimilar).
The weld will take on the characteristic of the ferrous metal.
Hope this helps till you get better advice
Paul
Title: Re: welding
Post by: Head Womble on February 16, 2013, 10:07:33 PM
From what I understand (I'm not a welder) cast iron can be welded, but will often crack along the edge of the weld if put under any strain.
Dissimilar rods are for welding two dissimilar metals, you need the right type depending on what metals they are.
Title: Re: welding
Post by: Rotary-Motion on February 16, 2013, 10:54:50 PM
hey mark
its not cast
just iron or steel, one of um? how do i tell???
Title: Re: welding
Post by: K.H on February 16, 2013, 11:09:36 PM
Your pic doesn't work for me.
Title: Re: welding
Post by: Rotary-Motion on February 16, 2013, 11:20:19 PM
is it the glove on one hand?
Title: Re: welding
Post by: Jamesrl on February 16, 2013, 11:42:57 PM
Now Now boy's play nicely, anyway back to the other rods, the welding ones.
You can weld stainless to mild steel using either stainless or standard steel rods BUT it's better to use stainless rods to prevent the  stainless component rusting along the fusion line.
Title: Re: welding
Post by: K.H on February 16, 2013, 11:54:18 PM
Not the friggin avatar the one in the first post
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 12:09:27 AM
it was an FB link i wasnt sure it  would load anyone else see it?
Title: Re: welding
Post by: Julian on February 17, 2013, 12:10:40 AM
What?
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 12:14:47 AM
What?
bananas
Title: Re: welding
Post by: Julian on February 17, 2013, 12:18:15 AM
No
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 12:19:45 AM
there organic
Title: Re: welding
Post by: K.H on February 17, 2013, 07:43:08 AM
What?
Facebook
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 08:58:23 AM
could i use the rothumbergur gas torch and solder?
Title: Re: welding
Post by: julianf on February 17, 2013, 10:33:10 AM
i dont know what youre wanting to join (cant see the photo) but if its such a weak joint that you would consider solder, you might want to have a look at adhesives, as some of them can be very strong.  if you have a large contact area may be able to create a bond stronger than what's sticking out.
i think one of the little lotus sports cars has its chassis glued together, rather than welded.
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 10:39:29 AM
re done pic can you see it now?
Title: Re: welding
Post by: julianf on February 17, 2013, 11:37:24 AM
is it some sort of ninja killing tool?
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 11:42:39 AM
crossbow bolts i got a big vampire cull to sort :)
nar, there fishing rod rests...
Title: Re: welding
Post by: julianf on February 17, 2013, 11:45:45 AM
i dont know what youre wanting to join, but id think its got to be easier to turn up a ring of steel and fasten it with a grub screw?
Title: Re: welding
Post by: julianf on February 17, 2013, 11:47:05 AM
...or just glue it (silkaflex, or just aryldite etc).  If its just a fishing rod, its not heavy.  Or are you talking about the fins at the bottom?
Title: Re: welding
Post by: K.H on February 17, 2013, 11:50:39 AM
You could silver solder/braze with the torch and MAPP gas but you would have to ask James if its suitable for the metals
Title: Re: welding
Post by: Julian on February 17, 2013, 12:06:18 PM
When you say iron in the OP, do you mean mild steel?  Mild steel and stainless steel will silver solder very well.  In the past, I've used the same rod and flux as I use for copper.
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 12:18:43 PM
yes maybe mild steel?
yes to botom fins i need to weld those fins on a stick this part gets pushed in the ground
Title: Re: welding
Post by: Head Womble on February 17, 2013, 01:12:03 PM
Why do you need the fins ?
Is it to stop the buggers twisting ?
And what's this got to do with bio/veg ?
Title: Re: welding
Post by: Jamesrl on February 17, 2013, 02:03:18 PM
He's after the Cod Liver Oil, bleedin' obvious innit.
Title: Re: welding
Post by: K.H on February 17, 2013, 02:58:29 PM
Its in "chatter" = everything else  ;D
Title: Re: welding
Post by: Rotary-Motion on February 17, 2013, 03:22:38 PM
hmmmm
 :o
