General => Chatter => Topic started by: Julian on September 13, 2015, 09:27:47 PM
Title: Sourcing a connector
Post by: Julian on September 13, 2015, 09:27:47 PM
I'm trying to locate a cheap source of these in the UK.  I can find them in China if I want to buy 500 on an FOB basis.
I only want around 10 off with circa 150mm x 1 - 1.5mm² tails.
Is there a generic name for them and besides trailers in the USA, where are they used?
I thought I've seen them on RC models but searches don't seem to bring them up.
Appreciate any help.
(http://www.palmergroup.co.uk/Bio/Connector.jpg)
Title: Re: Sourcing a connector
Post by: kamaangir on September 13, 2015, 09:37:08 PM
No link!
Post by: Julian on September 13, 2015, 09:47:36 PM
No link!
To what?
Post by: dgs on September 13, 2015, 10:18:50 PM
They are nearly the same as I used on r/c cars. They are called bullet connectors.
Post by: greasemonkey on September 13, 2015, 10:57:20 PM
I guess these are a bit pricey, if you want 10?
http://www.ebay.co.uk/itm/MOTOROLA-DM3400-GM340-GM350-GM900-DC-POWER-CONNECTOR-PLUG-LEAD-DOUBLE-BULLET-/351487273035?hash=item51d646284b
Other wise, just put "Bullet connectors" into Ebay. Single ones, male and female, are pence.
Post by: Julian on September 13, 2015, 11:16:40 PM
I've been searching bullet connectors, but didn't find that ad, GM ... good find not too bad a price.
Same bloke does 10 for 18 quid ...
http://www.ebay.co.uk/itm/10-x-MOTOROLA-GM340-GM300-GM350-DC-POWER-CONNECTOR-PLUG-LEAD-DM3400-MAXTRAC-/351495072458?hash=item51d6bd2aca
Always wonder where he buys them from though.
May buy one to see if it fits my application first.
Post by: GedsJeep on September 13, 2015, 11:34:31 PM
hey use them on kids 12v ride on cars ect...
Post by: kamaangir on September 14, 2015, 12:01:27 AM
You lot must have been polishing your crystal balls harder than I did mine, Julian said he was looking for a cheap source of these....
 :o
Post by: kamaangir on September 14, 2015, 12:02:14 AM
What about deans connectors? used in RC and can handle high currents.
Post by: GedsJeep on September 14, 2015, 12:18:09 AM
http://www.hobbyking.com/hobbyking/store/__31818__EC5_to_5_5mm_Bullet_Connector_Battery_Adapter_2pcs_bag_UK_Warehouse_.html?strSearch=5.5mm
http://electriflyer.co.uk/deans-female-4mm-bullet-connector/
or look at this lot...
https://www.google.co.uk/search?q=bullet+connectors&safe=off&espv=2&biw=1920&bih=947&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAmoVChMI87aZ7ZH1xwIVgTXbCh3hXQfJ#safe=off&tbm=isch&q=5.5+bullet+connectors
Post by: Julian on September 14, 2015, 12:38:40 AM
They are coming in at £1.80 each complete with tail, which isn't too bad for what I had in mind.  Would be nice if they can be had cheaper, though.
The look like good connectors, but the problem is I need to supply this type to match up with connectors already on existing machines.
Post by: Julian on September 14, 2015, 12:42:53 AM
Sorry, but all the wrong type!
I've seen them described as Hopkins connectors in the States, but I think that's just a trade name rather than a generic one.
Post by: greasemonkey on September 14, 2015, 08:24:05 AM
Looks like what you are looking for is called an SAE 2 way flat moulded trailer connector. Doesn't seem as though they are cheap.
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=SAE+2-Way+Flat+Molded+Trailer+Connector&_sacat=0
Just realised you have got them cheaper than that anyhow. I guess they are expensive because they are made up to a certain spec. Should be cheaper ones about, maybe not with the SAE mark on them. Doesn't look like they are on Ebay though.
Post by: Julian on September 14, 2015, 09:05:47 AM
Yes, done searches on SAE and "flat bullet" connector.  SAE is just a US standard, so may not be the actual type name.
Anyhow, I've ordered one of the £2.65 ones from "knickerlessparsons" (a trading name that fills one with confidence) on ebay that you flagged up.  If that fits, the bulk buy of 10 @ £18.00 will do fine.
Many thank for all the suggestions.
Post by: greasemonkey on September 14, 2015, 09:22:34 AM
Ha ha, that's precisely what I thought. Probably seemed like a good idea when they made the account.
Post by: Julian on September 16, 2015, 04:58:12 PM
I'm sure you're all bursting with curiosity to find out if the plug fitted (Yeah, right ... but I'll tell you anyway)
Fits a treat, wire size is right but the bally colours are round the wrong way!
I could probably get round it with judicious use of shrink wrap however, has anybody tried dying/painting pvc wire?  What about upholstery paint you used to get for vinyl car seats?
If I could make them both black that would do.
Post by: knighty on September 16, 2015, 06:46:04 PM
the seller might have them with the colours the other way around ?
the male of one connector plugs into the female of the other connector.... so you'd need different wire colours for each pair of connectors otherwise the wire colours would swap ?
Post by: greasemonkey on September 16, 2015, 06:56:30 PM
They must be handed. A matching pair will have male and female opposite colours to its butty.
Post by: Julian on September 16, 2015, 07:33:12 PM
I know I may look pretty daft, but I've already asked the question ... he only sells that orientation to match up with Motorola equipment.
Post by: greasemonkey on September 16, 2015, 10:03:23 PM
Oh, bit of snag, then. Looks like your into coloured insulation tape.
Post by: kamaangir on September 17, 2015, 03:27:16 PM
What you want is some one with a 3d printer.......... :P
Post by: knighty on September 18, 2015, 02:33:59 AM
you can buy reels of heat shrink....  you could cut it to the right length and do a bunch all at once ?
hot air gun / paint stripper thingie work great for heating/shrinking it
Post by: Chug on September 18, 2015, 09:32:00 AM
Maybe it would be easier to change the existing connector to something else like standard bullets?
Post by: Julian on September 18, 2015, 11:03:06 AM
If I can only buy connectors in this orientation, then using two the same will still result in the colours being mismatched!
The idea would be to supply a battery c/w connector for people to fit to an existing machine, so I've no control over the other connector.
Post by: Chug on September 18, 2015, 02:53:00 PM
I meant just snip off the connectors you have and replace with standard bullet connectors.
Post by: Julian on September 18, 2015, 05:27:29 PM
Ah, sorry, got you!
Good suggestion but not possible for logistic reasons I'm afraid!
