General => Chatter => Topic started by: Tony on July 12, 2015, 10:19:31 PM
Title: Diesel runaway
Post by: Tony on July 12, 2015, 10:19:31 PM
https://www.youtube.com/watch?v=SiBxwGQQ8Js
Feel sorry for it as it thrashes itself to death, surely one of them has a CO2 extinguisher to squirt into the inlet, or a knife to cut the turbo pipes off?
Title: Re: Diesel runaway
Post by: Keef on July 12, 2015, 10:30:45 PM
You'd need a large lump of bravery as well as a co2 fire extinguisher or a knife!
Post by: julianf on July 12, 2015, 10:48:03 PM
Tony,
I never asked - your delicate died from runaway?  What were the specifics on that?
Post by: Tony on July 13, 2015, 09:17:00 AM
The pump shaft seal failed (despite changing it a while back) and because I was assisting fuel flow through the 10" filter housing I'd installed with a facet pump, the sump filled with bio/engine oil mix without me noticing.
First symptom was an unexpected surge of power when overtaking uphill on a motorway, the next time I touched the throttle the engine immediately went flat out with RPM gauge off the top of the red, torque converter was just slipping (couldn't take the power) and it made a lot of loud rattly noises.  I imagine the motorway behind me was a bit smoky but I was too busy white knuckling it to the hard shoulder to notice.
I was going to rip the turbo hoses off, but it died down on its own fairly quickly.  At that stage there was oil peeing out onto the hard shoulder.
I don't think anything was seriously broken, I think it just blew a few seals, but I'd had enough of the Delica at that point to bother with fixing it up (had to do a lot of welding for the last MOT, transfer box output bearing was knackered as was the rear diff seal, and it was the one I spilt a 60l drum of veg into the back of) so decided to call it quits.
A chap bought it off me and as far as I know had it running for a while because it was insured according to askMID, however it's not been that way for a while so I think it's reached its end of life.
The Largo at least has the fuel pump on a belt at the rear of the engine so any leaks can't end up in the sump.  I have mixed feelings about the Largo, it corners much better than the Delica, but it's not as powerful (could do with Nisaan's 2.7 lump in it) or as solidly built.  Looks pretty enough for an MPV though.
Post by: greasemonkey on July 13, 2015, 10:21:25 AM
The air cleaner is accessible without going under the bonnet anyway. Bet it's some thick old pipe on it though.
I must admit though, when my Vitara ran away on the drive, I legged it. I honestly thought it was going to turn into a grenade. It didn't, but there was no way I was going under the bonnet with noises like that coming out.
Left it a month, then started it a few weeks ago. Started fine, but boy does it stink of burned aluminium.
Post by: Tony on July 13, 2015, 12:06:56 PM
I suppose the way to look at it is that a car is not worth the risk of injury, though it's hard for me to accept that when I've invested in it (in terms of time fixing it up).
Post by: Glycer-rides on July 13, 2015, 09:24:50 PM
Oh well, at least it went out 'guns a blase', rather than turning the engine oil into a mushy polymer.
I think Arash's Golf mk3 checked out that way?
