Biodiesel => Biodiesel equipment => Topic started by: dgs on June 08, 2015, 11:59:59 AM
Title: Drying Biodiesel.
Post by: dgs on June 08, 2015, 11:59:59 AM
I'm sure we all dry our biodiesel in one way or another. From testing lots of peoples samples, I'm sorry to say that most ways don't seem to work. Bubbling with ambient air, sprayring devices, etc.
Now don't get me wrong here guys, I'm not trying to preach to you but I think getting the water down to reasonable levels is important. I personally like mine down to below the german spec of 300ppm. I know lots of others would disagree.
One of the difficulties we face is that testing bio for water is not one of the easiest tests we can do.
For years I dried my bio by bubbling with ambient air. When I got my Sandy Brae I was horrified that the level was 8 to 900ppm. I never had any trouble with my bio, but at the time it was going into two older indirect injection vehicles. I gave a sample to a commercial producer who had a KF and he confirmed the 800ppm.
So I thought I would do a simple experiment and put the compressor inlet into a cardboard box. At the opposits side of the box I cut a flap and directed a small fan heater to inside. I left it for 4 hours. Result was 400ppm water.
It was after this that I got interested in making one of IMB's turbo dryers. He had experimented with all sorts of things, dehumidifiers, fan heaters, spray devices etc and in the end came up with this idea.
I will post a drawing when the wife comes in (still learning)
Basically the dryer is a plywood disc that sits on top of the processor/wash tank. On top of the disc is a 10-15 litre plastic drum with a sealed lid. on top of the drum is something like a tuppaware sandwich box with about 2" of self-indicating silica gel inside. Small holes are drilled in the lid of the sandwich box and the base (through the top of the 15 litre tub)
inside the tub is an aquarium bubbler, with the pipe going down to the tank bottom. At the back of the plywood disc is a 4" computer fan pulling air out of the headspace, driven from a small led transformer also inside the tub. All joints, lead exits are sealed with silicone.
The air pump can only pull air that has come through the silica gel, as the air goes down the line it gets warmed by the biodiesel (50 to 65 degs)
The results my dryer gives are;
before dryer after water washing, @ 1200ppm
after 4 hours 500ppm
after 7 hours 150ppm
after 13 hours 50ppm
I usually leave mine 7 to 8 hours, the 13 was just to see.
I heat the bio to 60 degs, when it gets to 40 I start the dryer, when at 60 I leave it for 3 hours, then swith off the heat, when it gets down to 40 I turn off the dryer. Total time 7 to 8 hours.
Title: Re: Drying Biodiesel.
Post by: knighty on June 08, 2015, 02:29:11 PM
aren't you limited by the amount of water the silica gel can absorb ?
I assumed you'd need shed loads of it for something like this
does dewatering at a higher temperature not have the same effect ?
Post by: dgs on June 08, 2015, 04:14:13 PM
No, not at all. My silica container is a see through plastic coffee container (simply so I can easily see if the silica needs changing) about 2/3 full this holds about 600gms and will work for up to 10 hours. I do 50% of the drying cycle with the silica from the previous drying, then change it for new(dried)
I have 2kgs in total and simply leave it on top of the c/heating bioler to re-dry.
Higher temperature helps, but there are electric costs to consider and remember you are at the mercy of the R/H when you bubble with ambient air. So you could potentially be drying to a very low level because of the temp, but wetting it all the time with the moist air. There are also oxidation issues to consider if heating to high temperatures.
Post by: Julian on June 08, 2015, 11:11:30 PM
That's very close to what I've been doing for about a year, but without the ullage space fan.  I don't think my set up works because I've probably ruined the silica gel trying to dry methanol ... it hasn't changed colour since I made the set up.
My desiccant is in a jam jar.  The inlet is a dip pipe through the desiccant to the bottom of the jar and the outlet is from the empty space at the top.  I had tried a long acrylic tube filled with silica gel in conjunction with a small compressor, but I don't think it held nearly enough.
I think I may need to invest in more desiccant!
If you recon it's an effective means of drying, we could do a wiki page ... would we need to get permission to use the design?
Post by: dgs on June 09, 2015, 10:41:43 AM
I asked IMB a while ago if I could use the details on the UK forums, he didn't have a problem, great guy.
(http://i60.tinypic.com/1606bv6.jpg)
Originally the design had an additional fan in the tub that blew down on the headspace, although it worked, it pulled too much air through the silica and thus meant it needed changing every 3 hours or so.With this version only the one fan pulling out is required.
Using one of the 'sander' wooden air diffusers has made my set up a lot more efficient (more very tiny bubbles)
The drawing doesn't show the silica gel container on top of the 15 litre tub. I have built quite a few of these for people, usually after they have visited and seen mine.
I think a wiki page on this would be excellent. I know the 13 hour test I did is totally impractical, but it gives some idea of how efficient the dryer is and it is very difficult to get bio down to 50ppm water.
Post by: knighty on June 09, 2015, 12:17:34 PM
is it not better to circulate the air through the silica gel instead of pulling fresh air in all the time ?
Post by: dgs on June 09, 2015, 02:25:10 PM
That could be a very good idea. If the air coming out of the extraction fan was at lower RH than the ambient air then you are correct, it would work more efficiently.
Post by: Bio-boy on June 14, 2015, 08:34:02 PM
Never had an issue with my drying process. 2hrs circulated via 2 drying bars and then decanted via a Cimtek Hydrosorb filter. Crystal clear ever time!
PS Forgot to mention the Venturi air extraction unit than is powered by my air compressor to draw the water vapour away from the Bio.
Post by: dgs on June 14, 2015, 10:01:26 PM
I'm not saying your bio is too wet Bio Boy, but how do you know it is dry enough? Being clear only tells you it is roughly under 1000ppm! From my experiance of testing peoples samples dried by using spraybars and the like, they don't work too well.
Post by: dgs on August 09, 2015, 09:19:38 PM
Over the last couple of days I have been doing a trial to see if I can get some correlation between the humidity of the air exiting the extraction fan in the turbo dryer and the actual amount of water contained in the biodiesel whist the drying cycle is underway.
This is the sort of R/H sensor I used.
                                        http://www.ebay.co.uk/itm/Mini-Digital-LCD-Thermometer-Hygrometer-Temperature-Humidity-Meter-Probe-Sensor-/361146290994?hash=item5415ff1332
It's just a cheap thing and probably not very accurate, however the object of the test was to see how the meter behaved in the 'wet' air from the surface of the biodiesel.
The biodiesel was first tested for water with the Sandy Brae, it was 600ppm. This was a batch that had been only settled for 10 days which is why the initial water level was lower than if it had been water washed.
The biodiesel was heated to 60degs in the wash/drying tank. When the temperature was at 40degs the dryer was started. Within a few minutes the R/H had dropped from an ambient reading of 57% to 52%.
The biodiesel was held at 60degs for 4 hours and after 2 hours the R/H had dropped to 30%. At this point the bio was tested for water which was 210ppm.
After the 4 hours the R/H had dropped to 26% and the dryer was left on until the bio temperature had dropped to 50degs. The biodiesel water content at this point was 120ppm. After the dryer was switched off the R/H sensor went back to reading ambient which was 40%
I have a biodiesel friend in the next village who has used this method for the last couple of years to indicate when his
bio is dry enough. He also leaves the dryer on until his sensor reads 26%. he has a manometer to check his water.
So as a cheap refrence it does seem to work. When I dry my next batch I will leave it drying until the sensor reads 26% then check the water content of the bio.
I do realise that there will be a lot of variables with this, also I don't think many use turbo dryers but I'm sure the sensor could be used with a lot of set ups.
As a matter of intrest I checked the soap level in this batch before and after centrifuging.
Before 42ppm After 16ppm.
Post by: Bio-boy on August 09, 2015, 09:26:23 PM
Any pictures of your set-up Dave?
Post by: dgs on August 09, 2015, 09:43:45 PM
I will post some pics tomorrow, also of the typical amount of residue I get in the centrifuge.
Post by: Julian on August 09, 2015, 10:05:58 PM
Interesting results.
Reduction in soap by centrifuging looks promising.  It would be interesting to see the results of a completed batch split, with half being centrifuged without washing and half water washed in your normal way.
When you consider the energy used to dry bio, centrifuging could represent quite a saving.
Post by: dgs on August 09, 2015, 10:23:13 PM
I'm sure the water washed batch would win hands down every time. the soap in my water washed batches is always <10ppm. Strangly enough though the glycerol residue in washed/settled batches seems to be the same. I'm sure my centrifuge is lacking some efficiency as with the peugeot 106 pas pump I can't get the pressure above around 56psi.
I've been speaking to Nathan who said when fuging bio the ideal pressure is 90-95psi so I think I will invest in a 'proper' pump.
There is the additional unknown question of the mono's when just settling. I have 2x 50/50 tests on the windowsill, one is washed and one settled. When we do a 50/50 the bio is of course is saturated with water, as the test settles depending on temperature the bio will totally clear, then if the temperature drops it will mist up. The bio in the settled batch will mist up at 3degs higher than the water washed batch and I'm sure this is due to the mono's being present. They were intentionally removed from the washed batch.
Post by: Bill on August 10, 2015, 08:02:01 AM
Monitoring the humidity in the space above the drying bio is how I dry mine. It is a splash dry arrangement. The software measures the voltage from the sensor to detect the minimum voltage or a value of 75% of the maximum value recorded during the drying process, which ever comes first. I don't bother to convert to RH.
Post by: dgs on August 10, 2015, 09:33:50 AM
Bill, have you ever checked the water level of the bio so you can relate it to the value in the headspace.
Post by: Bill on August 10, 2015, 03:24:51 PM
I've tried with a carbide manometer but the readings were small, so either the moisture levels were low or the method wasn't working to well for me. Must have another go at it sometime. Never tried to correlate any readings.
That's why the other thread about an electronic immersion sensor for moisture was worth looking into but so far I find that method less convincing.
Post by: dgs on August 10, 2015, 03:52:11 PM
Yes, I found the same. The manometers can be an absolute pain. Very roughly with most peoples manometers I think @ 180mms deviation equates to 500ppm (100gm or 110ml sample size)
When I get my arduino I will also be doing some tests re the immersion of the capacitance sensors.
Post by: GedsJeep on August 14, 2015, 03:54:29 PM
right, after a bit of work and fiddling, i think we may nearly be there on the scouse drying nozzle..
https://youtu.be/tXPGBvYYT0U
all it needed was a jubilee clip (hose clamp, whatever) to close the width of the opening.
it was too wide, causing a lot of splashback.
the vid is 160L of 90degC Wvo.
(maybe a bit too much but i got carried away...)
tam 105 is the pump.
Post by: dgs on August 15, 2015, 07:29:39 PM
tam 105 is the pump
GedsJeep is the operator
Scouse Drying nozzle is the equipment
Hope you solved the splashback problem with oil at 90 degC
Just tried another cheap sensor for comparison, Temp is only 0.2degs difference. R/H is 2% difference. I don't think that is bad at all.
Post by: Jonzeyboy43 on August 15, 2015, 08:59:17 PM
Dave is there 28 hours in your day?
Post by: dgs on August 15, 2015, 10:17:13 PM
You know what it's like when you get an obsession about something. I don't know what it is about getting involved with bio but it's sort of got hold of me like nothing I've known before. I must say I really enjoy it. I'm virtually counting the days to next years bbb.
Now I am about retired I can spend up to 30 hours a week collecting oil, brewing, pumping , pouring, experimenting, etc, etc. i find it relaxing and very satisfying.
When my missus sometimes comes into the bio room she just looks at me concentrating on something and leaves shaking her head.
Post by: GedsJeep on August 15, 2015, 10:28:13 PM
tam 105 is the pump
you`ll have to wait for the sequel.
splashback II more than a dribble
to find out.....
Post by: Bill on August 16, 2015, 08:14:03 AM
....When my missus sometimes comes into the bio room she just looks at me concentrating on something and leaves shaking her head.
Look more closely, she's probably rolling her eyes upwards at the same time.
Post by: dgs on August 17, 2015, 10:58:00 PM
Correct.
Post by: dgs on August 19, 2015, 08:53:58 PM
I dried another batch today using the turbo dryer and the cheap R/H sensor as reference. I left it at 60degs for 5 hours today as I couldn't get the R/H as read by the sensor lower than 30%. Last time it was 26% after 4 hours.
S/B test shows 105ppm. Todays ambient R/H was something like 20% higher than when drying the previous batch.
As the R/H of the air exiting the fan is considerably lower than ambient, next time I intend to duct the exiting air straight into the silica gel container, making it a sort of sealed circulation unit. It should in theory lead to much shorter drying times.
Post by: oakwoodtv on August 19, 2015, 10:30:01 PM
Won one of those sensors on the bay from America £1 37 with free postage.
Will have a play when it arrives.
Post by: dgs on August 19, 2015, 10:55:09 PM
Good lad!
Post by: therecklessengineer on August 20, 2015, 07:15:02 AM
Have you tried introducing the silica gel directly into the biodiesel? Via a nylon bag or somesuch?
Post by: dgs on August 20, 2015, 12:22:56 PM
No, never. I have seen posts where it works as an indicator for water, but I wouldn't like to try it directly. Even if it worked it would have to be washed with methanol to remove all traces of bio then re-dried.
In any case as I usually water wash the starting point is somewhere around the 1100ppm level and I'm sure this would soon saturate the silica.
Post by: Julian on August 20, 2015, 08:45:18 PM
I've not tried silica gel to dry bio, but I've tried using it to dry methanol ... that doesn't work.  The silica gel appears to absorb the methanol in preference to water.  The silica gel never seemed to work effectively afterwards.
I have tried those horticultural water absorbing crystals to dry bio ... that didn't work either!  They just sat there in the end of a stocking and did very little after an initial small swelling ... (sounds all too familiar these days!).
I'm good at failures, me!
Post by: dgs on August 20, 2015, 09:34:18 PM
Most things get harder the older you get Julian.
Post by: oakwoodtv on August 20, 2015, 09:51:35 PM
I would be happy to manage to get small swelling at my age.
Post by: Bill on August 21, 2015, 07:50:35 AM
During a TV interview with a theoretical physicist he said ' ... a negative result is as valuable as a breakthrough result, it serves to narrow the field of possibilities.'
Post by: dgs on August 21, 2015, 11:42:10 AM
That is virtually what IMB used to say, That a failed experiment can sometimes tell us as much as a successful one.
Post by: therecklessengineer on August 21, 2015, 03:26:00 PM
I'd argue that it's possibly more so as it combats confirmation bias.
Post by: dgs on October 24, 2015, 02:49:06 PM
I recently ran a drying cycle and monitored the r/h and temperature as read by the sensor, together with the biodiesel temperature and did a s/b water test each hour. Here are the results.
Time      Bio temperature       r/h-sensor      temperature-sensor    water s/b
start              65degs                50%                      26.3                  860ppm
+1 hour          66degs                42%                     27.4                  400ppm
+2 hours         66degs                36%                     27.5                  180ppm
+3 hours         67degs                30%                     28.5                  130ppm
+4 hours         67degs                28%                     29.0                  120ppm
The exiting air temp will slightly alter the r/h which could be corrected but I think the correlation is pretty accurate. I have now started to only use a 3 hour cycle as there is not much drying taking place during the last hour. if graphed the drying curve would be very exponential.
Post by: Julian on October 24, 2015, 06:08:01 PM
Excellent stuff, Dave!
Did you get the Arduino and LCD working?
What sensor did you end up using?
Have you tried the sensor directly in the biodiesel?
If you are running the Arduino, can I send you one of the cheap sensors I've been playing with?  Quite happy for you to dunk that in bio.
Post by: dgs on October 24, 2015, 06:19:27 PM
No, I haven't tried the sensor in bio, it's just the cheap one with the readout that I am using. By all means send me the sensor which i will try on the arduino (which I will get operational this week, promise) so get ready for some PM's, Cheers.
Post by: Julian on October 24, 2015, 06:45:42 PM
This is the DHT11 sensor and how to connect it to the Arduino.
Do you want me to include the resistor too and can you PM me your address?
(https://learn.adafruit.com/system/assets/assets/000/000/578/medium800/weather_dhtwiring.gif?1396764202)
Post by: dgs on October 24, 2015, 07:36:39 PM
PM sent.
Post by: Julian on October 25, 2015, 12:03:32 PM
Ok, it's on its way to you.
I popped in some small dia heat shrink so you can cover the solder connections.
It'll be very interesting to see how it relates to the SB measurements.
Post by: dgs on October 25, 2015, 02:04:12 PM
Indeed it will.
I've been thinking about getting some new titrant and solvent for the KF. It's an instrument that should really be in daily use and I don't really use it enough to justify spending about £150 with sigma aldrich.
Post by: slabster on July 03, 2016, 05:14:04 PM
A molecular sieve works for Methanol. I will dig out the link for it. slabs
Post by: slabster on July 03, 2016, 05:16:39 PM
Looking for a schematic plan to demeth / dry freshly reacted bio in an inert atmosphere hopefully via the reactor / venturi....
Post by: dgs on July 03, 2016, 09:53:19 PM
Not all, but most samples I test that have been venturi dried are high in water (5 to 800ppm) I think the answer would be to pull the incoming air through silica gel.
Post by: julesandtash on July 03, 2016, 10:06:30 PM
Mine came out at 300ppm water when dgs tested it yesterday which i was very pleased with
Post by: dgs on July 03, 2016, 10:26:42 PM
Yours was one of the few exceptions to the rule, Jules. You will have to tell others who dry this way your secret.
Post by: julesandtash on July 03, 2016, 10:28:42 PM
Warm clean Cornish air. Maybe the salt in the air drops the moisture level?
Post by: Julian on July 04, 2016, 01:48:07 AM
That's an interesting thought ... any one tried adding salt to bio to dry it?
Post by: dgs on July 04, 2016, 01:55:23 PM
I don't know about the salt but if Jules r/h is low it will certainly help.
Post by: terryecosse on November 06, 2018, 07:16:40 PM
I use a lot of salt for my emulsions , I thought I would be better after 9 years
Post by: dgs on November 06, 2018, 10:05:23 PM
At least it's better than using acid.
If you are getting emulsions from a slight underreaction it is due to monoglycerides. if the emulsion is from an overreaction then it is due to soap.
Post by: dgs on November 07, 2018, 12:48:52 PM
You have to get your bio into the 'Goldilocks' zone at the end of your reaction. Then after de-mething or 5% prewash there will be no emulsion when you water wash.
