Biodiesel => Biodiesel equipment => Topic started by: K.H on November 14, 2014, 06:20:23 PM
Title: What Capacitor? TAM 120
Post by: K.H on November 14, 2014, 06:20:23 PM
Blew the capacitor up today, it popped just where the ref numbers were, hopefully its just the capacitor, the user guide only says 33uF, anybody know what one i should be looking for?
Title: Re: What Capacitor? TAM 120
Post by: nigelb on November 14, 2014, 06:50:02 PM
Probably best to post on the other channel. Loads of folk with TAM's....not me though. Do you you want me to post for you ;D
Post by: Julian on November 14, 2014, 08:17:02 PM
Errr ... 15 TAMs out Nige!
Post by: nigelb on November 14, 2014, 08:32:55 PM
Not sure what you mean by that Julian!
Keith...Vijay has posted this from his TAM 105:
http://s522.photobucket.com/user/vijay9999pics/media/IMG_20141114_194557_zps702babf0.jpg.html
Post by: nigelb on November 14, 2014, 08:34:55 PM
Now I do....just re-read. Sorry
Post by: Julian on November 14, 2014, 09:10:06 PM
I've got a TAM 120 (least I think it is).  I'll open it tomorrow and have a look.
Post by: K.H on November 14, 2014, 09:48:03 PM
Cheers Nige  :)
Post by: nigelb on November 14, 2014, 10:09:43 PM
Vince has a 120. Says he'll have a look tomorrow when he's sober enough to enter his shed. I think he's been on the cider again. 8)
Post by: K.H on November 14, 2014, 10:53:13 PM
Err, i dont? :D
Post by: nigelb on November 14, 2014, 11:03:16 PM
Julian says I was 15 out.....a reference to my mis-understanding that your request was for a 105 cap rather than a 120. Just me being a dip-shit for not reading the thread topic correctly.
Post by: K.H on November 14, 2014, 11:04:46 PM
Ah, got it
Post by: Julian on November 14, 2014, 11:45:41 PM
I can do sums, me.
Post by: oakwoodtv on November 14, 2014, 11:47:59 PM
Found it in the manual.
http://www.clarkeservice.co.uk/manuals/water_pumps/tam_cpe.pdf
33 micro farad @ 450 volts.
Post by: Julian on November 15, 2014, 04:33:25 PM
This is what's fitted to my pump.
Although I bought it second hand, I've no reason to suspect it's no original ... looks like I'll be needing one soon too, so posting details of where you purchase would be appreciated!
Going to need a terminal box cover too, but I might have a go at printing one.
(http://www.palmergroup.co.uk/Bio/Tam 120 cap.jpg)
Post by: K.H on November 15, 2014, 04:58:18 PM
Yep, exactly the same as the remains of mine, strange as the manual says 33 and this is 40
Post by: nigelb on November 15, 2014, 06:45:55 PM
From what I remember of my capacitor melt down on the lowara you can fit one with a higher uF rating but not one with a lower value.
Post by: hifly on November 16, 2014, 12:45:43 PM
sorry to be late with the info, i put it down to dead brain cells, not sure how that happened  8)
anyway my tam 120 has a 40uF 450v ac Cap.
Vince
Post by: K.H on November 16, 2014, 01:32:25 PM
Vince
Cheers Vince :)
Post by: K.H on November 16, 2014, 07:01:49 PM
Is this suitable?
http://www.ebay.co.uk/itm/Run-Capacitors-most-appliances-start-run-motor-hoover-whirlpool-mfd-450v-/261596699974?pt=UK_BOI_Electrical_Components_Supplies_ET&var=&hash=item3ce860dd46
Post by: hifly on November 16, 2014, 07:12:18 PM
Yes, that is exactly the same as the one in my tam120, same size 92mm and same connections, just make sure you plug it in the right way round.
Post by: hifly on November 16, 2014, 07:17:16 PM
slight correction mine has no bolt on the end you may have to cut that off
Post by: K.H on November 16, 2014, 07:18:54 PM
Thanks again Vince
Post by: oakwoodtv on November 16, 2014, 08:34:51 PM
Just make sure you plug it in the right way round.
Motor capacitors are not polarized can be connected ether way round.
Post by: K.H on November 16, 2014, 08:40:59 PM
When i get it i may have to check on here, when it blew it blew the spade terminals off, so it might not be clear
Post by: hifly on November 16, 2014, 09:06:12 PM
Ok , did not know that
Post by: K.H on November 21, 2014, 06:05:56 PM
Well the new capacitor hasnt cured it, how do i test the windings just to be sure its dead?
Looks like i will have to fork out a couple of hundred :(
Post by: Julian on November 21, 2014, 06:09:03 PM
Even though it's new, it might be worth testing the capacitor too ... but it'll take someone smarter than me to tell you how!
Hope it's no the capacitor because I just bought the same one last night.
Post by: oakwoodtv on November 21, 2014, 06:32:27 PM
Check for continuity of the windings should be a few ohms between the live and neutral terminals
and between the two terminals that the capacitor connects to.
From the casing to live neutral and capacitor terminals should be open circuit or a very high reading.
Post by: oakwoodtv on November 21, 2014, 06:41:03 PM
With a meter on a mid ohms range connect to the capacitor a good cap will read low resistance
and rise to open circuit in a few seconds reverse the cap and it will do the same.
This is only a rough and ready check.
Post by: K.H on November 21, 2014, 08:32:51 PM
Cheers, Will do
Post by: K.H on November 22, 2014, 06:19:11 PM
All well and good, turned out it has also melted the black connection box, so the live wasn't going to the capacitor, had to replace it with a choc block, not ideal but it runs
Post by: Julian on November 22, 2014, 06:28:30 PM
Good news!
My capacitor should be here next week, but I'll be running a batch tomorrow so I just hope the old one holds out!
Post by: oakwoodtv on November 22, 2014, 06:38:32 PM
one connecter block or a new pump no contest.
