General => Chatter => Topic started by: Julian on March 09, 2014, 09:09:42 PM
Title: Off topic electronics/electrics question ... sorry!
Post by: Julian on March 09, 2014, 09:09:42 PM
3D printing efforts are progressing slowly but proving very rewarding.
Three times now my creations have been thwarted by a power cut and what appears to be an over zealous RCD in the fuse box.  The computer side of things continues to work fine because it's running off a lap top with a good battery, but the power for the printer comes from the 12v side of a large ex PC power supply, which shuts down, ruining the print.
I suspect I know the answer if not the reason why, but could I run the 12v from the power supply direct to a couple of sturdy 12v batteries and then on to the printer?
If I can't, in terms a 6 month chimp could understand, what would I need to make the arrangement work.  I know UPS's exist and would do the same job, but finances won't stretch to a decent one at the moment.
Title: Re: Off topic electronics/electrics question ... sorry!
Post by: greasemonkey on March 09, 2014, 09:34:04 PM
I can't see any reason why not. How many amps does the printer need? Your battery is going to need to be able to supply this.
Connecting the PSU to the batterys might be a different story, coz it's not really a charger. Someone else will have to advise about that.
Say your printer draws 10 amps, then a 100 amp/hour battery should in theory keep it going for 10 hours. If it draws 20 amp, it'll keep it going for 5 hours, and so on. In reality, it will be somewhat less than theory, but more than half. You could really do with a deep cycle battery.
It should say on the printer how many amps it draws.
Don't take my word for it though, I'd rather someone else be responsible for any damage.........
Post by: Julian on March 09, 2014, 09:48:50 PM
I can't remember exactly what current it uses.  I've got a couple of reasonably servicible Disco batteries sitting in the garage.  I'm sure they would keep the kit going long enough to reset the trip or outlast a power cut (they tend to be quite short round here.
As you say it's the connecting the battery to the power supply bit that strikes me as a bit dodgy.
Post by: greasemonkey on March 09, 2014, 09:59:42 PM
I can't imagine its pulling huge power. I would have thought it would be fine. Just run it by it's self, without any charging.
Charge it up well before use, and let it get on with it. You'll soon know if it's going flat.
Post by: Julian on March 09, 2014, 10:17:39 PM
Ah, I see where you're coming from.  Only problem is this plastic printing lark is a bit like bio, you don't sit there for hours and it can be several hours if you're aiming for a quality print, you tend to set it going then leave it to it's own devises.  So you may not be there if the batteries start to go flat.  I'll have a think around it but I'd like to try and used both mains and battery backup.
Post by: greasemonkey on March 09, 2014, 10:22:22 PM
Hmmm, so it could easy be pulling 10 amp, what with the heater and everything, and five hours at that could easy drain a 100AH car battery to the point where it was struggling.
I'd say a deep cycle, plus a battery charger, but then I'm guessing it has to have a pretty clean electric supply, so a battery charger might not be giving that.
Dunno, some that knows more than me will have to suggest something. Out of ideas.
Post by: julesandtash on March 10, 2014, 05:54:16 AM
Depends on how voltage critical the printer is.
In my caravan I have a 13.8v switched mode power supply in parallel with the leisure battery. All the time the mains hookup is on, the powersupply produces output and the battery floats at 13.8v
When there is no hookup, the battery supplies power, slowly running down to somewhere near 12
The power supply is one of these....
http://www.ebay.co.uk/itm/350W-13-8V-25-3A-Switching-Power-Supply-RADIO-K30-/380836025652?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item58ab989534
I have used them in the last couple of vans I have had and they work very well
If needs be, you could always put a 12V regulator after the battery(s) and before the printer although, to be honest, I suspect it would be perfectly happy anyway
Post by: Bill on March 10, 2014, 07:56:47 AM
Or is it easier to get the RCD problem sorted out?
Solve the problem, not the effects of the problem.
Post by: Tony on March 10, 2014, 07:59:33 AM
Got to be careful with charging lead-acids, particularly where deep cycle is expected.
If they don't have much charge they will try and draw a LOT of current on recharging which can lead to damage, so have to initially be current limited until the voltage hits 13.8V.  Then they can be switched to just voltage charge (aka float charge) as your regime suggests.
Car batteries and charge system are designed to keep batteries at the mostly-charged end of the scale which is how cars they get away with just a float charge system without current limit - and why running a car battery down is bad for it, as the alternator will happily provide the battery with damaging current when it does recharge.
Having designed charge circuits for lead acids I'm not sure there is a simple way to do this.  The only way I can imagine is an intelligent lead-acid charger and then hanging your load off the battery at the same time (which isn't great as the charger won't know about it and may make incorrect assumptions about the battery, and a lot of smart chargers use a PWM pulse system for the charge profile which may interfere with your rep-rap).
Tricky one.
Post by: Dickjotec on March 10, 2014, 08:00:36 AM
Off post but how is the 3d cad going?
Post by: Julian on March 10, 2014, 11:06:59 AM
Bill ... Yes, certainly replacing the RCD is a must but it won't cover power cuts.
Jules ... how does that unit switch?  It looks for all the world like a straight forward power supply I have for the LEDs in the kitchen.
Dick ... I persevered with Sketchup for the time being.  I think the issues I've been having may be a bug in the software, but I've managed to produce some reasonable parts ...
This is a modified printer part to part embed and fix in place a little servo motor to automatically sense bed level.
(http://www.palmergroup.co.uk/3D/Modified%204%20bearing%20X%20carriage4.jpg)
And this in the same part, modifying it and adding a couple of cooling fan ducts.
(http://www.palmergroup.co.uk/3D/Modified%204%20bearing%20X%20carriage3.jpg)
I hadn't forgotten about it, but I'd like to hang on to your SolidWorks for a little longer until I'm confident in my abilities with Sketchup, if that's OK with you.  I perhaps need to try and upgrade Sketch up to see if the "bug" is solved, but in the latest version the gearwheel add-on doesn't work ... nothing is ever simple!
Post by: Dickjotec on March 10, 2014, 04:21:21 PM
3d is looking good. Keep the solid works as long as you like, when / if it comes home I will only feel the need to try it out,
Post by: Julian on March 10, 2014, 04:55:13 PM
You should ... try it out that is.  I'm an absolute novice at Sketchup, but it's incredibly rewarding drawing a set of parts intended to fit together and then printing them to find that they do!
It's a strange feeling.  Ordinarily when you want to make an item and have to hunt around to find a bit of suitable stock or perhaps weld two bits together.  With this you dream up an idea, draw it and make it.  Kind of liberating really!
One other thing, the ability to look at the back of an object is amazingly intuitive.  I find myself on the web looking at photos (not that type of photo) and trying to spin them round to get a better view.
Post by: Dickjotec on March 10, 2014, 05:36:14 PM
I use sketchup for building work and have found it very easy to use. I have not tried it on mechanical parts. I must get a 3d printer one day and have a go. I used to teach pro desktop and found that good for engineering projects but have not got a personal copy.
Post by: Julian on March 10, 2014, 05:57:12 PM
When using sketchup, have you had planes that split into unbounded triangles or shoot unbounded triangles off into space?
Let me know f you want to build a printer.  I recon with a lot of hunting around, you could put one together for around 180 quid.  I think component prices aredropping all the time.
Post by: Dickjotec on March 10, 2014, 07:57:30 PM
Yes and other strange effects that I had not expected but for free software I am very impressed with it.
I will keep your printer offer in mind but realistically I already have too many projects on the go!
Post by: julesandtash on March 10, 2014, 08:03:04 PM
It doesn't, it just supplies 13.8V at the output as long as the mains is on. No mains, no output.
In the caravan it is just in parallel with the battery and, as such, maintains it at float voltage. Loads connected to the battery just draw power from the power supply (unless they exceed it's capacity I guess but nothing seems to do that).
When there is no mains power, the loads just take their power from the battery.
I know it is probably not the best for the battery but it works. Most caravans have a similar system (just the commercial ones are a lot more expensive).
Post by: Julian on March 10, 2014, 08:36:17 PM
So what you're describing is what I described in the first post? Or am I being my usual thick self?
Post by: Julian on March 10, 2014, 09:03:27 PM
Glad I'm not the only one.  There seems to be very little info on the problem available on the net.  That glitch has cost me hours, but appart from that Sketchup seems to do pretty much every thing I want at the moment, biggest limitation is my inability to use it!
Post by: Julian on March 10, 2014, 10:12:33 PM
For those interested here's the finished item ...
(http://www.palmergroup.co.uk/3D/Servo complete.jpg)
Those are M3 bolts and the servo is only 12mm thick.
Post by: julesandtash on March 11, 2014, 06:04:48 AM
No your are not being thick, that is basically what you described in your first post.
I was more pointing out that it is a tried and tested system that should work, even if it isn't the kindest to your batteries in the long run
The only addition is a possible voltage regulator between the batteries and the printer if it is particularly keen on regulated 12V. If it has it's own voltage regulators on board then unlikely to be an issue.
Post by: therecklessengineer on March 11, 2014, 06:29:59 AM
If it helps, that's exactly the system used on many ships for backup power, including the one I'm on at the moment.
Post by: Julian on March 11, 2014, 10:05:55 AM
James, Jules, thanks.  I'll have a check on how fussy the electronics are ... I have a feeling something in there is quite sensitive.
Where should the regulator go if I need one?  On the input to the printer after the transformed suppply and battery have been commend or on the battery supply before it's connected to the transformed supply?  I'm guessing the latter.
Only issue will then be how to smuggle two dirty batteries upstairs without the domestic authorities noticing.
Post by: therecklessengineer on March 11, 2014, 12:00:48 PM
Batteries are actually very good at keeping a voltage nice and smooth without spikes.
I'm sure that the electronics will drop the voltage to 5v or even 3.3v for everything sensitive. The heater and nozzle might be unregulated 12V, however, I doubt these will put up much fuss at 13.8V.
If you want a regulator, it'll need to go after the supply and batteries and before the printer. However, there might not be enough overhead voltage in the event of power failure to run the regulator. It'll need to drop normally around 1.5V to work properly.
The alternative is to use the batteries as a +24V supply and then use a 24/12 DC/DC converter. But for that price, you might as well buy a UPS. Here's one for £35. http://www.ebay.co.uk/itm/UPS-Uninterruptible-Power-Supply-650VA-/390792861873?pt=UK_Computing_Uninterruptible_Power_Supplies&hash=item5afd11d8b1 (http://www.ebay.co.uk/itm/UPS-Uninterruptible-Power-Supply-650VA-/390792861873?pt=UK_Computing_Uninterruptible_Power_Supplies&hash=item5afd11d8b1)
If the batteries are bad, just use yours! It looks to be a 24V model.
Post by: Julian on March 11, 2014, 12:53:00 PM
Thanks.  The Arduino board is OK with up to 20v and as far as I can gather the RAMPS can handle the same voltage, so I may give it a go.
James, a while back you sneaked in a comment about building a printer yourself ... how's it going?
Post by: photoman290 on March 11, 2014, 03:14:33 PM
i agree with reckless. the easiest way is to just get a ups and use that. i have a 350 watt one kicking about if you cant find one. it is 36 volt,  like most of them so you would have to sort out some batteries for it. it is a sine wave one so kinder on the electronics than a msw one would be. sometimes that doesn't matter sometimes it does. i would find out how much current it draws for a first off as that will dictate how big a ups you need.
Post by: therecklessengineer on March 11, 2014, 04:52:35 PM
Badly. :(
Small life redirection resulting in no funds available for fun.
Post by: Julian on March 11, 2014, 05:34:56 PM
Badly. :(
Oh, sorry to hear that. Doesn't sound good ...hope it gets sorted soon.
Post by: therecklessengineer on March 11, 2014, 08:54:36 PM
It's good actually. An entirely conscious decision on my part rather than being thrust into anything unprepared. Let's just say I'm going to be a student (yet!) again for a year - so I'm going to need funds for supernoodles.
Thanks for your concern though!
Tony...watch out. I'm coming your way. :P
Post by: Tony on March 12, 2014, 02:07:52 PM
Cool.  I'm a Soton alumnus - got my MEng there. :)
Post by: kamaangir on March 13, 2014, 12:09:15 AM
Is that why you want to sell your 80 cruiser?  :'(
Post by: therecklessengineer on March 13, 2014, 05:58:59 AM
One of the reasons yes. Want to buy it? Comes with a free tank of fuel.  :P
