Biodiesel => Biodiesel equipment => Topic started by: whatarascal on November 15, 2013, 11:57:23 AM
Title: selling pumps
Post by: whatarascal on November 15, 2013, 11:57:23 AM
Is anyone here selling pumps.
Or would you recommend a pump around 120lpm
Title: Re: selling pumps
Post by: Tony on November 15, 2013, 01:16:02 PM
K.H uses a big Tellarini from this range for his processing:
http://www.tellarini.com/inglese/prodotti2b_ing.htm
I have a couple of them, a little one ENM25 (53lpm) to transfer oil and a brand new big one ENM40 (149lpm) which is "in the collection" but I've not found a use for yet.
They really are beautiful pumps, as they self-prime, are reversible, are ever so quiet in operation and not closed impeller like a lot of pumps of that flow (so less likely to block).
I'm trying to work out if I would be willing to part with the bigger one, since I'm not using it - but you know what it's like, part with it then want to use it for something like building a big processor.
If you want pressure for running a venturi/eductor well then the multi-stage Calpedas are the bees knees - the MHXM range.  Stainless lovelyness and great for pressure, however closed impeller so can block up with lumps in the oil.
http://www.calpeda.com/products/mxh
Do occasionally turn up on eBay.
Post by: whatarascal on November 15, 2013, 03:34:07 PM
I should think the   ENM 40 would be ok for my venturi as I only use it for demething.I suck the methoxide in via processor pump.
The ENM40 looks like far to big a pump than you need  ;D
Post by: whatarascal on November 15, 2013, 03:49:34 PM
Are these any good
http://www.ebay.co.uk/itm/UK-44CI10A1-Pedrollo-CP-Centrifugal-Pump-CPm100-0-33HP-0-25KW-220V-/350909438961?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item51b3d51bf1 (http://www.ebay.co.uk/itm/UK-44CI10A1-Pedrollo-CP-Centrifugal-Pump-CPm100-0-33HP-0-25KW-220V-/350909438961?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item51b3d51bf1)
or this
http://www.ebay.co.uk/itm/UK-47HF5M1BA1-Pedrollo-HF-Medium-Flow-Rates-CENTRIFUGAL-PUMP-HFm51B-0-85HP-0-60K-/350909442365?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item51b3d5293d (http://www.ebay.co.uk/itm/UK-47HF5M1BA1-Pedrollo-HF-Medium-Flow-Rates-CENTRIFUGAL-PUMP-HFm51B-0-85HP-0-60K-/350909442365?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item51b3d5293d)
Post by: K.H on November 15, 2013, 04:32:00 PM
The Pedrollos are ok, i use to have one on my plant,
BTW my batches are 300lt + thats why the big pump  ;)
Post by: Tony on November 15, 2013, 05:56:15 PM
Not a fan of Pedrollos, I have an 80lpm one with brass impeller, I would say it actually shifts about 50lpm and that's with hot bio.
Post by: Jamesrl on November 15, 2013, 08:17:19 PM
I've only had one Pedrollo pump, said to be 80ltr/min, it would only run backwards.
The most reliable and consistent pumps I've used are Stuart Turner 903, 80ltr/min (but turns out 90), tremendous flow and pressure.
Post by: whatarascal on November 19, 2013, 06:36:11 PM
well lets hope this one runs the right way.
http://www.ebay.co.uk/itm/350909442365?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 (http://www.ebay.co.uk/itm/350909442365?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649)
Post by: Jamesrl on November 19, 2013, 07:21:43 PM
600ltr/min?
That'll punch a hole in the opposite side of the drum.
Post by: whatarascal on November 19, 2013, 07:51:27 PM
600ltr/min?
 its a misprint init
Post by: Tony on November 19, 2013, 08:58:55 PM
HFm51B top flow rate is 300lpm but it doesn't have much power behind it (quite a flat curve, low max head) so will be nowhere near that with veg.
Post by: 1958steveflying on November 19, 2013, 11:23:54 PM
600ltr/min?
 its a misprint init
The 600lpm is the HFm5A
