Oil Feedstock => Oil coarse filtering, settling, drying and storage => Topic started by: julianf on October 24, 2013, 12:25:26 PM
Can anyone tell me what the exact concerns are, with regard to storage?
I suspect there will be two issues - fire, and environmental health, and that the regulations may differ for each?
The exact things im interested in are -
bunding requirements
total storage limits
There will, im sure, be variations on bunding limits relating to proximity to water courses.
Thank you.
With regards to EA, I'm pretty sure that bunding isn't strictly enforceable if you are not industry but 5000 litres is an enforceable maximum you can store without a permit.
If you are following bunding requirements, it is much easier to bund many smaller containers than one big one.
ie. if you bund an IBC, the bund would need a much higher capacity than a single bund for 5x200 litre barrels.
• Oils and chemicals are stored in an area where spills can be contained. This should be within an impermeable bund. A bund is a secondary containment area that holds liquids if the main containers leak or break. If you have one oil storage container in a bund, the bund must be able to hold 110% of its volume. If you have more than one container in a bund, the bund must be able to hold 25% of the total volume of the containers or 110% of the largest container’s volume. Bunds should be inspected regularly and rainwater removed;
• Tanks should be located at least 10 metres from watercourses and steps should be taken to minimise the risk of damage to the tanks/bund by impact.
No idea on fire regs though.
