Biodiesel => Biodiesel equipment => Topic started by: alifreddy on September 22, 2013, 09:30:06 AM
after using my processor for about a month the pump is leaking when I turn it on to circulate bio. it looks like its coming out of a little hole.
It leaks only a little. I put a bucket under to collect and is pumping most of the liquid around. I had some solid jelly type koh in the bottom of processor after last batch so I put a litre or 2 of methanol in the processor then drained it off.
Sounds like the shaft seal has failed. What pump is it?
not sure can take a pic all numbers rubbed off
can it be repaired and will it get worse want to make enough bio between now and end of october so not making bio in colder months
an unknown pump, with an unknown fault?
can it be repaired, and will it get worse?
best guess - unknown.
My best guess is
1 possibly
2 probably
3 unlikely
In this case your best bet is to have it apart to see which seal is leaking and replace it.
showed pump to my builder and he said its just a gasket. so we will take it apart and maybe just make a gasket he said
Doupt it but good luck.
A photo of said pump, with a closeup of the leaking bit would enable us to diagnose it properly...
I reckon the builder will probably know best
might have to agree with you.
Can we fix it yes we can
did i mention that i'm a builder. got some no more nails in the van, that will fix it
i once sealed a leek in a petrol tank with nail varnish :)
There's no need for the nail varnish. I just shoved the Leek in and put the filler cap back on. That trapped him good and proper. Never worked out how to escape. ;D ;D ;D
muahahaha
take pics tomorrow
(http://carrottspc.files.wordpress.com/2010/03/can-we-fix-it.jpg)
I suppose its lucky that your the type to have nail varnish on you :P
Aha! You're still alive then?
