Biodiesel => Biodiesel equipment => Topic started by: Oilybloke on May 23, 2013, 06:28:19 PM
Title: Venturi.
Post by: Oilybloke on May 23, 2013, 06:28:19 PM
 Right, so close now to getting started.........but have I cocked up the venturi/condenser pipe work? On drying the oil, the venturi is sucking water from the drain pipe into the tube that goes to the venturi, only getting a dribble out of the drain.
(http://i41.tinypic.com/bgqwxc.jpg)
(http://i43.tinypic.com/orpi52.jpg)
Title: Re: Venturi.
Post by: julianf on May 23, 2013, 07:07:30 PM
I dont have a specific answer, however...
I never understand why people run the condenser when dewatering - why not just vent to atmosphere?
Its not like you want to be saving the water or anything.
Title: Re: Venturi.
Post by: Jamesrl on May 23, 2013, 07:18:45 PM
You've got your return pipe in the totally wrong place, it should be on a breather pipe off the distillate vessel NOT on the outlet of the condenser.
Title: Re: Venturi.
Post by: Julian on May 23, 2013, 07:30:44 PM
Has he? ... if the open ended Cu pipe to the right in the second photo is the "vent to atmosphere" (needs running outside by the way), then it looks OK to me.
If that's the case, then it rather sounds like the condensate from the condenser isn't separating from the air flow and could do with something like a plenum to slow the air flow down or re-plumbing to stop flow entering the venturi suction..
I could be wrong ... it has been known!
Title: Re: Venturi.
Post by: Oilybloke on May 23, 2013, 07:36:21 PM
Thank you all. Jim, I copied this set up from HC's ex processor, and his works fine.......
Title: Re: Venturi.
Post by: Julian on May 23, 2013, 07:49:20 PM
I you're sure the pipe work is correct, I suspect that the condensate is running out of the condenser and down the lefthand side of the vertical pipe.  Unfortunately you have the venturi suction on the same side, so I'd guess the condensate flow is running and being sucked back to the venturi.
As a quick fix, try putting the venturi suction hose on the open Cu pipe on the right hand side and a vent to outside (running upwards from the Cu pipe) where the venturi suction currently is.
Long term fix would be a plenum arrangement.
Title: Re: Venturi.
Post by: Oilybloke on May 23, 2013, 08:01:16 PM
Googles 'plenum' and scratches head to recall distant Latin lessons...........
Title: Re: Venturi.
Post by: Rotary-Motion on May 23, 2013, 08:06:12 PM
cant work that pipe work out, but is that a calor gas cylinder tank?
Title: Re: Venturi.
Post by: Oilybloke on May 23, 2013, 08:22:51 PM
Nope, it's a 300 litre water tank.
Title: Re: Venturi.
Post by: Rotary-Motion on May 23, 2013, 08:30:27 PM
nice tank  8)
Title: Re: Venturi.
Post by: Julian on May 23, 2013, 08:45:00 PM
nice tank  8)
Nicer if it wasn't galvanised!
Also is the position of the heater a little high, or am I missing something out of shot?
Title: Re: Venturi.
Post by: Oilybloke on May 23, 2013, 08:58:36 PM
nice tank  8)
S/S Julian, and there is another element below.
Title: Re: Venturi.
Post by: Julian on May 23, 2013, 09:45:43 PM
Ah, I stand corrected, sorry .... but what's the texture on the bottom of the tank in the bottom photo?  Looks for the world like really heavy galvanising.
Title: Re: Venturi.
Post by: Head Womble on May 23, 2013, 10:02:40 PM
It looks like the residue left after scrapping off insulation to me.
Title: Re: Venturi.
Post by: Julian on May 23, 2013, 10:31:21 PM
Sorry, I missed this post.  A plenum is basically a void.  If you have an air flow through a chamber larger that the pipe entering it, the flow will slow down.  This will allow any entrained liquid to drop out and run to a drain rather than carry on round the circuit.
You may find altering the piping may works almost as well ... come out of the condenser into a T instead of the elbow.  Arrange the T so that the air flow goes up and the fluid drains down.  Block the existing pipe to the venturi and use the pipe on the right as your vent.
Title: Re: Venturi.
Post by: Julian on May 23, 2013, 11:04:28 PM
Like this ...
(http://i42.tinypic.com/678iys.jpg)
Title: Re: Venturi.
Post by: Oilybloke on May 24, 2013, 06:31:39 AM
Julian, many thanks. I will give that a go.
Title: Re: Venturi.
Post by: Jamesrl on May 24, 2013, 09:34:17 AM
So how do you safely vent your Methoxide and Distillate vessels.
Title: Re: Venturi.
Post by: Julian on May 24, 2013, 11:01:39 AM
Distillate vessel is on the pipe labeled "drain" and hence is vented by the pipe to the right labeled "vent".  And yes, of course the methoxide vessel will need a vent, assume that's out of shot like the second heater, or yet to be fitted.
Title: Re: Venturi.
Post by: Oilybloke on May 24, 2013, 08:35:59 PM
........and it works. Cheers again, I owe you a pint!
Title: Re: Venturi.
Post by: Julian on May 24, 2013, 08:49:33 PM
Glad to help ... don't forget to put the vents in place!
