Biodiesel => Biodiesel equipment => Topic started by: RIngrey on March 04, 2011, 02:43:24 PM
Title: ***Looking at Methanol recovery***
Post by: RIngrey on March 04, 2011, 02:43:24 PM
My processor doesn't support methanol recovery. As I have plenty of Glycerine (Potassium based) I'm looking at recovering the methanol if possible. I was looking at buying a small still so that I could distill the meth from the glycerine. Would this work? ???
Title: Re: ***Looking at Methanol recovery***
Post by: Tony on March 04, 2011, 02:45:51 PM
Have you done any water prewashes IE contaminated the glycerol with water?
Post by: RIngrey on March 04, 2011, 06:45:28 PM
No prewashes as I seem to produce good results without doing it. So my glycerine is uncontaminated with water.
Post by: Tony on March 04, 2011, 07:39:16 PM
You should be good to go on recovering Meth from the Glycerol then :)
Post by: RIngrey on March 05, 2011, 02:32:49 AM
Will a Still do the job?
Post by: Tony on March 05, 2011, 09:31:32 AM
Yes, but it might just be easier to add a condenser to your processor and heat it in that (assuming it's not plastic?)
You don't need a venturi for it to work, you'll still collect the Meth - though this could be speeded up by bubbling air through it.
Post by: hifly on March 06, 2011, 01:05:32 PM
if you are in the uk you will find it difficault to buy a still as they are ilegal to sell, i made one from a berco boiler to de-meth my glyc, i fitted a bubbling ring in the bottom to force ait through the condencer. worked fine.
Post by: K.H on March 06, 2011, 02:53:57 PM
Hifly stills are readily available on ebay,they get around the law by saying "for distilling water"
http://cgi.ebay.co.uk/Smart-Still-Still-Spirits-Distillation-unit-/110565063299?pt=Home_Brew&hash=item19be30fa83
Post by: Tony on March 07, 2011, 10:52:09 AM
The more I hear about bubbling air in being an effective way to push off the Meth, the more I want to try it on my processor to see if it speeds demething up.
It makes sense pushing an air bubble all the way up through the liquid you want to Demeth, which will also help with agitation.
Post by: Stumpy on November 14, 2013, 10:00:25 AM
I always bubble air in through the drain on my processor, it speeds up the methanol reclaim vastly on my plant.
Post by: Julian on November 14, 2013, 11:53:50 AM
I tried bubbling from the processor, through the condenser using a small compressor, for quite a time.  It worked very well, nearly doubling what I can distill with the venturi and sometimes over loading the condenser.
I had problems, however, in humid weather, as the recovered methanol appeared to be absorbing the moisture from the in coming air.
A water trap on the air line made no difference and I got half way through making a desiccant dryer, but the resistance through it was quite high and drying the desiccant would have been a pain, so I reverted to using the venturi.
Post by: Jamesrl on November 14, 2013, 02:18:23 PM
That's where a Squirrel excels, rapid demeth and no moisture drawn in, add a still head heat exchanger and the condenser can cope with a greater volume of vapour for less energy input.
Post by: Julian on November 14, 2013, 03:55:21 PM
I tried a Squirrel and mine certainly didn't excel!
Post by: Jamesrl on November 14, 2013, 05:09:06 PM
And by your own admission neither do your Venturis so me reckons your opinion on Squirrels should be discounted.
Post by: Julian on November 14, 2013, 07:08:36 PM
Did I express one?
Post by: Dickjotec on November 15, 2013, 08:25:34 AM
I use a squirrel and find I can overload the condenser, a quad pd, however bubbling the vapour through the recovered meth gets the rest of the meth vapour to liquid. I have a bubble ring in the processor that I use for the last hour of demeth with the heater off to get the last meth out and help drop the temp of the bio before decanting to the settling tank.
Not as fast as Jim's demeth, I am sure, but I often get 6l an hour at max.
Oick
Post by: Jamesrl on November 15, 2013, 09:08:45 AM
It's not difficult to overload  a quad with a Squirrel,   a SHHE helps but doesn't solve the problem totally so I just throttle back the venturi.
As far as speed goes I demeth bio only in 45mins and WBD (not that I do it nowadays) in 75mins.
