General => Wiki and forum discussion => Topic started by: Julian on March 04, 2013, 12:29:27 AM
Title: Viscosity cup page ... is falcon about?
Post by: Julian on March 04, 2013, 12:29:27 AM
I've just found a page started by falcon over a year ago.
Ron, from the stats, it would seem you were on line yesterday.  Looks like you were having trouble uploading photos and abandoned the page.  It was a shame, because it looks like a good idea which could be of use to quite a few folks.
Anyhow, I've taken the liberty of uploading a couple of your photos and laid out the page here ...  http://www.biopowered.co.uk/wiki/Viscosity_cup
Let me know if you think it's OK.
Title: Re: Viscosity cup page ... is falcon about?
Post by: 1958steveflying on March 04, 2013, 09:22:25 AM
That's a good idea, I shall be looking for a suitable ladle now.
Post by: Rotary-Motion on March 04, 2013, 05:52:03 PM
blending biodiesel with miss fuels will never be the same viscosity of 100% keresene would it?
Post by: nathanrobo on March 04, 2013, 08:06:16 PM
Can think of some useful applications for this:  For example comparative viscosity tests with bio after different processes.
Post by: Head Womble on March 04, 2013, 10:07:09 PM
It could also  be used to monitor the effects temperature has on bio and veg in the winter,
after a while it should be possable to evaluate at what viscosity the filter will start to block.
Post by: Julian on March 04, 2013, 10:31:08 PM
As this seems to be generally accepted as a good idea by many, would it make sense to try and establish a "standard hole" for a specific volume ladle?
That way, if we established a "standard" temperature, we could compare viscositys between members (within reason)
Post by: Tony on March 04, 2013, 11:16:11 PM
Presumably shape also has an effect on the drain duration (wide and short vs thin and tall)?
Post by: Jamesrl on March 04, 2013, 11:46:14 PM
For accurate viscosity comparison, brewer to brewer, a standard cup will be needed.
Perhaps the top of the ubiquitous 2ltr pop bottle with a standard hole size in the cap.
Post by: Julian on March 05, 2013, 01:07:57 AM
A standard container would be a good idea.
Don't those pop bottles deform too easly?
Using some type of packaging would mean it's widly available though.
Post by: Rotary-Motion on March 05, 2013, 06:11:37 AM
good piont also amount of oil needs to be the very same level in everybody cup aswell as being the very same cup as mentioned. i see this on a run of the mill 200 ltr drum, when full 200 ltr and you open the crud valve i can shoot a jet 2 foot in a downward arc, half full onlt achieves a 1 foot and so on... the downward force acting on the amount of volume makes a diff.
Post by: Head Womble on March 05, 2013, 06:49:32 PM
It's the height of the head that makes the difference, 100L and 50L will produce the same pressure at the bottom for the same given head (no smutty remarks needed).
Post by: Rotary-Motion on March 05, 2013, 06:54:09 PM
 8) lol hehe
Post by: K.H on March 05, 2013, 10:20:02 PM
I have one from my spray kit i used it when testing the coldflows
Post by: Head Womble on March 05, 2013, 10:54:28 PM
Keith, your avatar looks lie RM in a goldfish bowl.
Post by: Julian on March 08, 2013, 07:01:00 PM
Just been looking at the winter addatives page and it's obvious KH used a viscosity cup for the tests.
What did you use Keith?
Post by: Jamesrl on March 08, 2013, 08:26:05 PM
You've answered your own question, a viscosity cup.
Post by: Julian on March 08, 2013, 09:08:03 PM
Doh, silly me!
So they're all the same dimensions with the same size hole then?
Post by: Jamesrl on March 08, 2013, 09:18:10 PM
Doh, silly me!
Dimensions are irrelevant, A viscosity cup is a viscosity cup innit.
Post by: Julian on March 08, 2013, 09:22:03 PM
Thought we were trying to arrive at standard cup or container.  If you are only making comparisons with the same cup, yes, I'd agree.
Post by: Dickjotec on March 08, 2013, 09:53:13 PM
For a standard cup how about a length of copper pipe with a drilled stop end?
Post by: Julian on March 08, 2013, 10:07:01 PM
Nice and standard, but this is one for paint ...
(http://image.classictrucks.com/f/37211743/1205clt-05+12-spray-gun-tips+viscosity-cup.jpg)
I'd guess we need to be looking for a similar shape.  I recon the cone is preferable to a flat bottom to ensure all the fluid gets drained.  I think Jim was on the right track with a pop bottle.
Post by: Dickjotec on March 09, 2013, 08:49:23 AM
Hear what you say but a 22mm stop end is no flatter than a pop bottle lid and can be domed out if wanted. The hole size, which I think is the most important for uniformity, will also be more accurate when drilled in copper than plastic.
Post by: julianf on March 09, 2013, 09:41:26 AM
I feel like i might be missing somthing, but i think that the chance of making a 'standard' by drilling holes is, well, unlikley?
Isnt the key to just calibrate whatever container is made?  Ie find the level that it needs to be filled to to empty in 25 seconds with a 25sec sample / temp?
Post by: Dickjotec on March 09, 2013, 01:50:44 PM
I think a standard sized hole is the starting point, different sized holes will have different effects as the viscosity changes and while any hole can be calibrated to one viscosity, as you say, there is no guarantee that  two with different sized holes will remain calibrated with different viscosities. With a standard hole the device can be tuned as you suggest.
Realistically I think it unlikely that we will be able to rely on data from different cups when the viscosities are close together.
Post by: K.H on March 09, 2013, 04:06:59 PM
I did reply on page 1, yes a cup very similar to that pictured from my spray set
Post by: K.H on March 09, 2013, 04:09:05 PM
As i have already posted up findings with my cup would it make sense to base it around that one?
Post by: Julian on March 09, 2013, 04:15:27 PM
Missed that, sorry ... so how big is your hole!
Post by: K.H on March 09, 2013, 07:07:42 PM
I will put a drill bit up it tomorrow!
Post by: Jamesrl on March 09, 2013, 07:36:17 PM
Don't forget to warm it up and mind your haemorrhoids when inserting.
